C3 exhaust pipes vendor - NCRS Discussion Boards
  • Jeff M.
    • February 1, 1999
    • 127
    I will be replacing my pipes on my big block 71 4spd and will be keeping my current mufflers only (DYNOMAX). Who makes the best pipes and does any body make mandrel bent front and rear pipes that i can fit to my muflers. I can get the pipes from corvette central for 250 bucks??? Not bad, but do they fit good and not hang low?? My current system is completly welded in one piece and needs to be cut to get out the rear end. I also noticed that when i had the guy put in the H pipe that it enters the main tubes about 3/4 inch and is restricting the flow. Anybody make an X pipe?? Please, any thoughts or ideas are appreciated.
  • rick spears
    Re: C3 exhaust pipes vendor
    i just finished installing the aluminized exhaust system that i bought from corvette central on my 70' 350/350hp car. i bought the entire system from them with the magnaflow mufflers. it fits great and sounds good too. it is the 2" to 2 1/2" system, and i'm very pleased with it.....rick
