Screw pn 161901 description please - NCRS Discussion Boards
  • Alan Drake
    The 63/64 JM calls for the rear aluminum bezel (around license plate area) to be secured by 2 pan head slotted screws with integral washers. The AIM shows (pg223)four locations for screw # 161901 which looks like a slotted pan head. Every C2 I look at has a pan head phillips and the repro I order are also pan head phillips. Besides requiring 4 screws not 2 as JM calls for,
    what should these screws look like????
    Thanks Alan
    Wish I could find a parts manual covering screws.
    Re: Screw pn 161901 description please
    Alan-----
    GM #161901 is a PAN HEAD, CROSS RECESS (Phillips) head screw. It is a #10-12 thread, 5/8" in length, pointed tip, and zinc or cadmium plated.
    • Alan Drake
      Re: Screw pn 161901 Repro's
      Thanks Joe,
      I'll put the repro's in if unable to find originals in my junk box.
      Appears the 63/64 JM section 17 needs a correction.
      • Dick W.
        • 10483
        Send that correction to the appropiate team leader. His email can be found in the contacts section of the NCRS.org site.
        Dick Whittington
