Re: If you have an agreeable NAPA dealer
Verne------
The problem with this strategy is that most, if not all, commercial rebuilders tear down starters to their individual components, then build starters of whatever configurations they need from the assorted pieces.
The starter frames (i.e. the part with the "numbers" and "dates" on it) are interchangeable for a huge number of different starters. There's no more reason to expect that a frame with the "242" (or, any other number) will be built up into a starter for an original "242" application than for almost any other configuration/application. The starter frame is among the most "generic" of all the starter components.
So, while one might find a "242" starter this way, I'd bet that you'd have to look through quite a few units to find one. Just about any GM starter application rebuilder's part number would be as good as any other to check out, though.
One thing that would narrow it down somewhat is that the "242" was a non-HD starter. So, applications using a HD starter would not be a good candidate to look for a "242". The frames are slightly different for HD and non-HD starters. While they can be converted, I don't think that many rebuilders would go to the trouble unless they were short of the required cores.
Verne------
