68 Oil Pan Plug - NCRS Discussion Boards
68 Oil Pan Plug
  • Kurt B.
    • July 31, 1996
    • 971
    68 Oil Pan Plug
    My smallblock oilpan presently has a small head plug and I seem to recall many many years ago seeing oil pan plugs with larger heads (size of a nickel or quarter)than the head on the plug I have. Is the following plug correct for a 68 smallblock:
    9/16 hex head with a 7/8 metal flange molded to the bolt, thread size is 1/2 by 20 and of course there is a white plastic/fiber washer.
    Is this the correct plug or should I be looking for a larger head type plug?
    Thank you,
    Kurt
    Re: 68 Oil Pan Plug
    Kurt-----
    The plug you need is the one you've got. Your search is over before it began.
    • Kurt B.
      • July 31, 1996
      • 971
      Great News, Thanks Joe *NM*
