Why would oil pressure get higher? - NCRS Discussion Boards
  • Geoff C.
    • May 31, 1979
    • 1613
    Re: Why would oil pressure get higher?
    Geoffrey-----
    I would expect a "hot-and-running" oil pressure of about 45 PSI for your engine. If, indeed, that's what it was, but it's now as you described, then I expect that the most probable culprit would be a sticking oil pressure relief valve (in the oil pump). The valve consists of a "piston" and a spring. Sometimes the "piston" can fit too tight in the bore in the oil pump cover and consequently stick or bind.
    • Terry F.
      • September 30, 1992
      • 2061
      I think a spun bearing might do the same. Launching can cause this to happen. But, I think you would start to hear it soon enough, maybe not. Not an engine expert.
      • Tom H.
        • December 1, 1993
        • 3440
        Have you tried a direct oil pressure gauge to be sure you are getting a correct reading on your in car gauge?
        Tom Hendricks
        Proud Member NCRS #23758
        NCM Founding Member # 1143
        • Dale S.
          • November 12, 2007
          • 1224
          Before they staryed putting a bypass in the filter we saw this problem. That was one of the problems they had. I went on a few warranty calls for Fram in early 1960's on ther first Ph-8. They added the PH-8A which had the built in bypass.. I saw some that were bulged out and blown off. Filters now have the by pass. Dale
          • Geoff C.
            • May 31, 1979
            • 1613
            • Rick S.
              • January 1, 2003
              • 1203
              Geoff, not to hijack your post but I have a similar question. I have a a 67 327/350hp (L-79) and my guage would indicate under 30 after warm up. I replaced the copper line and now the guage pegs at 60 all the time. Does anyone have any suggestions.
              Rick
              P.S. Mine also returns to zero at shut off.
              • Gerard F.
                • June 30, 2004
                • 3803
                How about an earl and filter change,
                Geoffrey. As they would say in the Bronx, ----or Brooklyn.
                Why get complicated.
                Queens Boy
                Jerry Fuccillo
                #42179
                Jerry Fuccillo
                  Geoffrey------
                  I'm not too big of a believer in "chemical repair agents". However, I don't think that most of them will do much harm. So, it might be worth a try.
                  One thought here: if the engine in this car has gone a long while between starting, it may be that all of the oil "departed" the oil pump surfaces. If only the slightest amount of corrosion formed in the oil pump pressure relieve valve piston, that would be enough to cause it too stick.
                  • Geoff C.
                    • May 31, 1979
                    • 1613
                    • Mike M.
                      • May 31, 1974
                      • 8365
                      Jiffy Lube? near sacrelegious. get off the couch, put away the Frito lays and change the oil and filter yer self. regards, mike
                      • Geoff C.
                        • May 31, 1979
                        • 1613
                        Help, I've fallen & my ambition got broke *NM*
                        • Gerard F.
                          • June 30, 2004
                          • 3803
                          A Propensity for Joking Around
                          Learned that at CCNY, Geoffrey.
                          Try that diesel 15W40 C1-4 plus. Just works great in my 67 S/B.
                          Jerry Fuccillo
                          #42179
                          Jerry Fuccillo
                          • Clem Z.
                            • January 1, 2006
                            • 9427
                            make sure the oil filter bypass valve in the
                            oil filter adapter is still in place when you change the oil filter
                            • Chuck S.
                              • April 1, 1992
                              • 4668
                              When was your last oil change, and, er...who did it...Lube N' Go? Any chance they could have slipped some 40W oil in by mistake?
                              With the temperatures beginning to drop, this sounds more like high oil viscosity. I have exactly the same behavior on my 2006 in the fall/winter if I get on it before the oil temp is above about 150 deg...and it's running 5W-30. Right after start up, oil pressure is about 45 at idle, over 70 at 2500-3000rpm...consequently my driver info read-out stays set on engine oil temp now.
