I am having trouble identifying the correct vacuum advance to be used with the 67 427/435 with T.I. Can anyone help? Thanks.
67 427/435 Vacuum advance.
Tags: None
- Top
Re: 67 427/435 Vacuum advance.
Rick-----
I'm fairly sure that the one that you need is GM #1116163. I'll confirm this later. By the way, this one is still available for a GM list of $18.26. However, its configuration may be slightly different from the originals in that it may lack the stamped-in part number derivative and max advance number.In Appreciation of John Hinckley- Top
