C1 Block Dates vs. Car Build Date - NCRS Discussion Boards
  • Jimmy J.
    • May 31, 1988
    • 304
    Would A 519 block with a casting date of L188 and a pad stamp F1219 be correct for a car built March 13, 1959? It is not a Corvette block. Thanks, Jimmy
    Re: C1 Block Dates vs. Car Build Date
    Jimmy -
    Yes, that casting and engine assembly date works (within the six-month "window") for a March car. Most of the block points are for the correct casting number and casting date, and the block you describe meets those criteria for full judging credit; you didn't mention the suffix after the "F1219", but if the suffix is incorrect for the Corvette application, you'd only get a deduction for an incorrect stamp (50 points on a '59).
    • Jimmy J.
      • May 31, 1988
      • 304
      John, The stamp pad is 1219D. What kind car or truck would this been in orginially? Thanks for your response. Jimmy
        If memory serves, the D suffix translates to 2 Bbl carb + automatic transmission...
