C1= ENGINE NUMBERS - NCRS Discussion Boards
C1= ENGINE NUMBERS
  • Dennis A.
    • April 30, 1999
    • 1010
    C1= ENGINE NUMBERS
    Lifted the body off the frame what begins as a 1962 restoration...Engine Stamped number FI028DB is not listed in my book...any help? block #3756519, I Identified as a 1959. Engine ran with a high lift cam...
  • GL Anderson
    Re: C1= ENGINE NUMBERS
    DB 1958 283ci 230hp 4bbl Powerglide This what the database in Chevy-Camaro shows for DB code. Same code was used several times thru the years.
    • Dan A.
      • May 31, 1974
      • 1074
      A casting date is almost always useful. The 3756519 casting was used from late 1958 production through the end of the '61 model year.
      DB in 1961 was used in a full size Chevy of 230hp (4bbl) with a powerglide. Same in '60, '59 and '58.
      Dan
