C3/rear spring - NCRS Discussion Boards
C3/rear spring
  • Ed P.
    • July 31, 2002
    • 270
    C3/rear spring
    Discovered today that I have a 7 leaf rear spring and should have a 9 leaf spring. Is eaton spring still the place to go for correct spring. 71 small block rag top. Thanks Ed
    Re: C3/rear spring
    ED------
    My feeling is that Eaton is the best source for the spring. It won't be a perfect reproduction, but it will be "close" and it will fit and function perfectly. Reports that I have received and inspections that I have made of cars with this spring installed seem to support the fact that it achieves correct ride height.
    • Mark #28455
      only the original is "correct"
      The repros all have some differences that will get a minor points deduction. The only truly "correct" spring is the original 9 leaf. Not to worry, there were TONS of the 9 leaf springs made (the 7 leaf ones are much harder to get). There was a recent Restorer article that showed the differences in the 9 leaf springs from 63 to 78. You can get a good core and restore it yourself.
      Mark
      • Juliet P.
        • June 30, 1999
        • 349
        Re: only the original is "correct"
        Here are some photos and information about the restoration I did on my '70 rear spring. I ended up getting a few used springs, taking them apart and piecing together one that gave the car the proper ride height. There are some subtle differences in the liners between repro and originals.
        ~Juliet
        2019 Sebring Orange 8-Spd Coupe (daily driver & autocross) 6k mi.
        1970 Bridgehampton Blue Convertible - Chapter Top Flight 2005 68k mi.
        1965 Coupe (Greg's project No Flight)
        Gone but not forgotten:
        1987 Yellow Convertible 199k mi.
        2002 Yellow Convertible 100k mi.
        2007 Atomic Orange Coupe 140k mi. RIP flood 2015
        2007 Lemans Blue 6-Spd Coupe 34k mi.
        • Rob C.
          • August 31, 2004
          • 144
          Re: C3/rear spring
          ED
          I put an Eaton spring in my 72 this past winter and I was happy with it.
          It did ride 2" high so I took it to a spring shop near by and the took care of that. The ride hight is great now. The spring also comes with this melted liner stuff on it wich is a little bit time consomming to get off but when you do Quanta has the best liners (I think).
          Rob
          • Ed P.
            • July 31, 2002
            • 270
            Re: C3/rear spring
            Thanks guys all the info helped I think. Not sure I like hearing 2" high ride height. That is the problem I have now with the 7 leaf. I got a Quote on an eaton spring that was alot higher than corvette central. I wonder who makes there springs? Ed
