My ampmeter was showing a slight discharge at any RPM. I noticed when I reved up to high RPM in neutral the meter would "POP" and the needle would jump over to charge. It would then work as notmal as long as the motor was running, but after turning off the ignition and restarting the same problem would reappear. I bought a new voltage regulator but the problem persists. Anyone have any thoughts?
Thanks, Walt Weems
Thanks, Walt Weems
