Warning: Undefined array key 5516 in .../vb/library/content.php on line 3508
Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510
Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737
Warning: Undefined array key "online" in .../vb/library/content.php on line 3522
Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614
Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165
Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182
Warning: Undefined array key "posts" in .../vb/api/user.php on line 183
Warning: Undefined array key "posts" in .../vb/api/user.php on line 189
Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480
Warning: Undefined array key "userid" in .../vb/api/user.php on line 204
Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246
Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342
Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594
Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610
C2 427 Carb - 3811 -
NCRS Discussion Boards
If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
A friend has the opportunity to purchase a cast iron intake and carb from a 1966 390 Horse Corvette. Intake number 3866948 and carb 3811. The carb has the part number and model number on it, but no date code. The seller claims it to be original and not a service replacement. Is this correct (no date code) for an original carb?
Thanks for the info. Intake has 66 date so it may be a 1967 intake and carb. Not sure of date code since a friend is looking at it. Original question is still should the carb have a date stamp if it is the original carb?
Rick,,,In my opinion (not worth a bunch) the 67 carb is not as good as the 66. I believe that the 67 has no external float-bowl adjustment. You have to take the bowl off and bend the arm. 66 had adjustable floats. I have always thought that it was a cheaper carb, not better. Others more knowledgeable than me may feel differently............Bill S
