When I got my '62 (about 2 years ago) the transmission would "grind the gears" when shifting from 1st to 2nd. About a year ago I had someone service the transmission which included replacing the syncho rings. Shifting improved but was not perfect. Lately it seems to have gotten slightly worse. There is a "grinding" when shifting from 1st to 2nd UNLESS I slow the shift - kind of like shifting from 1st into neutral and then into second.
Not knowing much about this I'm looking for suggestions. Is there some type of adjustment on the shifter linkage?
Any suggestions for an experienced shop in the Los Angeles area (Long Beach or vacinity) would be appreciated.
