Well my buddy's finally hit the wall on his 86 that he climbed a tree with.
Measuring the wheels center to center, his damaged wheel seems to be pushed back almost three inches!
He's convinced that the new/used upper control arm he purchased may be wrong and there are no numbers on the arms to use as a reference, just production numbers that the dealer can't use.
Other oddities that I've noticed is that the rack unit's traveling in front of the lower pully at an angle where it is barely missing the pully angling back to the damaged wheel.
I'm soliciting the help of fellow 86 owners or those who are intimate with an 86 to tell me if the rack unit is supposed to angle this way or not.
I'm telling him frame shop time but he's not giving up on the control arm possibly being wrong, throwing the wheel back.
For the sake of reference, the broken control arm has 3075217 stamped on the top edge at the front bushing, plus there is 20851 on the flat surface half way between the bushings. The replacement is 3120404 with 23953 on the flat surface.
What convices me that the part is correct is that the left upper control arm has the numbers stamped on the top/front at the bushing as well.
Any feedback is appreciated to put this to bed.
Chuck
Chuck
