1974 Coupe/454/Auto/AC/AIR/PS/PB
How do I identify the correct power steering pump for my car? I'm having a problem with belt alignment. The PS pulley is the two groove cast iron design. This pulley (rear edge) slightly rubs the face of the idler pulley. Is there a way to shim the PS pulley further forward? The other belts and pulleys are correct based on the AIM for my car. Since the idler pulley and PS pump share the same mounting bracket, neither can be adjusted. The pump is installed in a correct reservoir. Can this be the wrong pump and the shaft is too short?
