When I built my L76, in the interest of originality, I used the black, "as-original" lookalike intake manifold gaskets sold by one of our best known parts houses. I am almost certain that an oil consumption issue (uses 1 quart per 500-600 miles) that has been apparent for awhile is due to leakage from the lifter gallery into 3 or 4 of the right bank intake runners. Not sure whether to condemn the gaskets, or not.
Here is some background information. Leak-down test shows no ring sealing problems. On a recent dynamometer test the engine made good torque and power. However, blue smoke was apparent out the right sidepipe on the closed throttle part of the pull (redline back to idle). I have no reason to suspect valve guides, as they were checked and OKAYED before the recent rebuild. Valve seals are o-rings PLUS umbrella type, which look to be oriented and working properly. Under high vacuum, closed throttle operation, I understand that it's not rare for a poorly sealed intake, to suck return oil from the lifter gallery, while displaying LITTLE OR NO symptoms of a vacuum leak. The engine does have a persistent off idle stumble, which has NOT been cured by adjusting the pump timing, and going to a larger pump nozzle. The heads were milled .015". The intake was not machined to match.
I will carefully remove the intake while keeping the gaskets intact, so that I can examine them. Is there anything that I should look for, specifically? I intend to replace with a Fel-Pro gasket set, using RTV instead of the front and rear gallery seals. Any better ideas? Is there an extra-thick gasket set that I can use? What is the limit to a combination of head/deck milling before machining the intake becomes necessary? Any other tips will be appreciated.
Thanks in advance.
Joe
Thanks in advance.
Joe
