58 Stamp Pad - NCRS Discussion Boards
58 Stamp Pad
  • Mike P.
    • June 30, 2001
    • 7
    58 Stamp Pad
    What do you guys think of this stamp pad? It's a 739 block with a Dec 18 cast date. Thanks, Mike
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    No see'um picture... *NM*
    • Dennis C.
      • January 1, 1984
      • 2409
      Now see'um picture... OK by me... *NM*
      • Dennis C.
        • January 1, 1984
        • 2409
        On the other hand...
        ...the more I look at the U character, I begin to see a circular, very light stamping at the top of the U. If old character was replaced with U, that might explain the "sanding marks" in that area... JMHO
        • John S.
          • September 30, 1997
          • 263
          Re: On the other hand...
          From the picture it appears that "Q" was restamped to "U".
          • Kevin M.
            • November 1, 2000
            • 1271
            Re: 58 Stamp Pad
            That's what I see and agree on the sanding marks.
            Kevin
            • Mike P.
              • June 30, 2001
              • 7
              Re: 58 Stamp Pad
              I have a higher resolution picture and it looks to me that someone ground down the last letter and stamped the U over top. The letter underneath is definately a G though. In 58 there was no "CG" code. DG was 230 hp with powerglide but there is no other suffix with a G in it. What I would like to know is do the broach marks look correct? And if they do, is it possible that the guy that stamped it on the line screwed up the stamp and just ground off the last letter and restamped it. It was the day after Christmas afterall. Mike
              • Mike E.
                • February 28, 1975
                • 5134
                Re: 58 Stamp Pad
                I don't have my resources with me--but is there a passenger car suffix with a "G" in it? That would be my guess as to what happened, which is much more likely than a stamping error at the plant.
                • Dennis C.
                  • January 1, 1984
                  • 2409
                  This call can confuse...
                  The broach marks in the critical area are gone forever. The rest of them look pretty typical.
                  In this era, often the last letter of the suffix was hand stamped later in the assembly process. For that reason, the last character can look "odd" in that it might be tilted, deeper, shallower, spaced differently than the others. I almost tend to "trust" that appearance rather than the perfect gang stamp that started a few years later. There were approximately 5 different Corvette engine asys in '58 that used a (first letter) C code.
                  I think many engines were assembled using common parts when possible and then later, when the intake and transmission demand became clear and installed, the 2nd suffix letter was stamped by hand individually.
                  I have to believe some factory "errors" were corrected on stamp pads, but in my experience, I have not seen one corrected in this particular fashion - but, there is a LOT of stuff I've never seen...
                  For now, my jaundiced (sp?) eye is in the lead...
                  • Kent K.
                    • December 1, 1982
                    • 1139
                    Re: 58 Stamp Pad
                    Mike,
                    In 1958, there was a 'CG' engine suffix used for 283ci, m/t, o.d., 230hp, 4BBL trucks & cars. The 'CG' suffix was used again in 1960 trucks & cars for 283ci, m/t, o.d. 170hp with 2BBL carb. In 1962, it was used for Chevy II & Kingswood 283 engines coupled with m/t, 4 speed and a/c but horsepower and carbs are not listed.
                    This information was found at http://www.nastyz28.com/chevy-engine-code-stampings.php
                    Regards, Kent #6201
                    Kent
                    NCM Founder - Member #718
                    • Chuck S.
                      • April 1, 1992
                      • 4668
                      Re: This call can confuse...
                      "...For now, my jaundiced (sp?) eye is in the lead..."
                      Er...Dennis, do you mean "lead" as in "out in front"...Or, uh...as in Pb, "a heavy elemental metal"...??!! I'm having some trouble understanding what yer trying to say here.
                      • Dennis C.
                        • January 1, 1984
                        • 2409
                        The pad has been tampered with, bogus..... *NM*
                        • Chuck S.
                          • April 1, 1992
                          • 4668
                          Re: The pad has been tampered with, bogus.....
                          I was tryin' to read you and Mike's lips cuz no sound was coming out, but I thought that's what ya'll wuz saying. Thanks for the clarification.
