On cars equiped with A/C 69/71 there are 2 switches below the left thumb wheel. These are electrical and have various operations. The rear switch is part #7310365 and is still available. The front switch is part #7310366 and is discontinued with no supercede number. Would someone have this switch or know of another source for this part. All help appreciated as usual.
A/C Part Needed
Re: A/C Part Needed
Check out www.partsvoice.com. Select "Locate part by part number", then select GM database from the pull down menu, enter the part number, enter your area code (not zip code), and click on "Find It". This came up with 5 dealers indicating that they stock this part. Good luck.- Top
