help ID bellhousing part no. - NCRS Discussion Boards
  • don izzo
    I have an aluminum bellhousing believed to be from a late 80's or early 90's Corvette. It bears the stamped number 6135AL12 on the back side just behind the mounting for the hydraulic slave cylinder for the clutch release bearing. Can anyone ID this housing? Thank you all.
    Don
    Re: help ID bellhousing part no.
    Don-----
    Unfortunately, that's not the information I need to ID it. There should be an 8 digit GM part number embossed on the bellhousing at some location. I've never seen a GM bellhousing that didn't have a part number cast on it.
