C2 Guage Cluster. - NCRS Discussion Boards
C2 Guage Cluster.
  • Richard S.
    • November 1, 1994
    • 809
    C2 Guage Cluster.
    Can someone please advise what year(65-67)and what motor the following cluster sticker would identify:
    LC
    Cluster:6456402
    Speedo: 6455367-w
    Tach: 6412522-w
    Thanks....
  • Rick S.
    • January 1, 2003
    • 1203
    Re: C2 Guage Cluster.
    Rick,
    The cluster label on my 67 roadster is also LC and it is a 327/350HP (L79).
    The rest of the label is not readable though. The blue ink date stamp is May 18,1967 which is before my June built car. Hope this info is beneficial to you.
    Rick
    • Stephen L.
      • May 31, 1984
      • 3148
      My 427 390 HP cluster Tag
      LC
      Cluster #6457982 60# Oil Pressure
      Speedo #645387-W
      Tach #6412322-W
      March 23 1967
      • Richard S.
        • November 1, 1994
        • 809
        Thanks guys....can I get some more input regarding the specific use and year.....thanks.....anyone??
        • Stephen L.
          • May 31, 1984
          • 3148
          As I said in my earlier post 390 HP 427 Dated March 23 1967. That would be for a 1967 BB 427 390 HP Corvette coupe. It's a 6000 rpm redline tach, 60# Oil Pressure, 250 deg temperature, 40 amps
          • Richard S.
            • November 1, 1994
            • 809
            Steve....what am I not understanding regarding your post. Your cluster sticker numbers are not the same as the cluster sticker numbers I posted. How do your numbers help me to identify what cluster my sticker identifies??
            • Stephen L.
              • May 31, 1984
              • 3148
              I don't have any info on other clusters and numbers. Maybe someone with the same numbers as yours will chime in and be able to tell you what theirs came out of. Sorry.
              If you have a 67 cluster, (hopefully there is a date on it) and it has a 6000 redline tach with 60# oil pressure Then it came from one of the following: L79 L36 or L68 engine. If it has 5500 redline then its a base engine car. If it has 6500 redline and 80# oil pressure then its a L71 or L88 car.
              I don't know the particuliars for other mid years.....
              • Rick S.
                • January 1, 2003
                • 1203
                Rick,
                I just read your profile, send me an email on what you need from my 67 tank sticker.
                Rick Smith
                • Richard S.
                  • November 1, 1994
                  • 809
                  Rick,
                  Thanks for the offer to share your 67 tank sticker information. If you have a picture or photocopy that would be great. If not, all I really need is the VIN number,Ident number,Date Received,Expected date of Production, Order number,and the handwritten assembly line identification number.....regards,
                  Rick.
