56 Wonderbar Radio - NCRS Discussion Boards
56 Wonderbar Radio
  • Greg
    56 Wonderbar Radio
    Can anyone help me find a working complete radio.
  • Patrick T.
    • September 30, 1999
    • 1286
    Re: 56 Wonderbar Radio
    Go to Corvettes at Carlisle in August, get there at 7AM on Friday when the gates open up, don't get there at noon. You'll find one, but it won't be cheap.
    Be aware that on '56 Wonderbars there was no "Wonderbar" on the seek button, that didn't happen until '57. I got a correct '57 Wonderbar up there that needed work, and after all was said and done, it worked perfectly after spending $2000. All for a stinking AM radio that only had talk shows and foreign language stations!!
    • James F.
      • December 1, 1985
      • 596
      Greg,
      The '56's had two types of Wonderbar Radios. The first style had a tube type power supply AND the radio chassis was thicker (higher from top to bottom, the same thickness as the '55 Wonderbar). According to the meager records that I keep, '56 Corvettes with vins almost to 1600 had this style power supply, possibly later. The second Wonderbar style had a transistor power supply and the chassis case was thinner, same thickness as the '57's. Power supply was the same as found on a '57. Appearance wise both radio faces's looked identical, power supplies did not. If you just want a '56 Wonderbar radio and are not concerned with NCRS Judging, the above will be of little interest. Regards
      • Dave Tooker
        I have a working wonderbar...but I do not have the correct power supply unit. Used one from a 56 chevy bel air and it worked with no problems.. Dave
        • Jerry Clark
          Hi Greg:
          Just go to your local boneyard and pull one from a Packard Caribbean, should be quite a few of those layin around
          jer
          • Doug B.
            • May 31, 1990
            • 5
            Same here re: 56 radio. All that happens with mine is that the light goes on. I take it that the three-pronged two-wire thingamajig is for the power antenna? Doug
            • James F.
              • December 1, 1985
              • 596
              Re: 56 Wonderbar Radio-Doug
              Doug, '56's did not have power antenna's. '56 Rear Carbs possible sources: Corvettes at Carlisle, Chicago Corvette, web site www.gccorvettes.com You'll need a lot of luck not to mention $$. Regards
              • Doug B.
                • May 31, 1990
                • 5
                Mr. Frakes, thanks for the help but what is that wire for? Doug
