I need some help!
1. not to sure if the washer pump works correctly, it clicks but never had any water in it. Is there a way to test this before I put it back on the car? should I have it re-conditioned if working while out?(washer @ wiper motor)
2. I bought a wiper arm removal tool but not quite smart enough to figure the thing out, HELP!
3. Once the arms are off I intend to repair as needed, but not sure of correct shade of black to use. and does that same color continue inside wiper compartment and linkage? where do I get it?
thanks for any advice you can give, Damon
