Posi or non-Posi Banjo - NCRS Discussion Boards
  • Roy B.
    • February 1, 1975
    • 7044
    People buying Posi third members know to look for a "P" on the case , but the Banjo with out looking inside how do you tell a Posi, non-Posi banjo?
  • Roy B.
    • February 1, 1975
    • 7044
    Re: Posi or non-Posi Banjo????????????
    Well I see every one must know how !!!
    • Dennis C.
      NCRS Past Judging Chairman
      • January 1, 1984
      • 2409
      Sorry you didn't get the standing ovation...
      ...you were looking for... :-(
      • Roy B.
        • February 1, 1975
        • 7044
        Re: Sorry you didn't get the standing ovation...
        Dennis ! How do you tell a Posi banjo housing from non-Posi housing by looking under the Corvette, disregarding the third member? Thanks
        • Dennis C.
          • January 1, 1984
          • 2409
          On my '62, I always check to see that it still...
          ...has the vent line and the little lube warning washer held in place by the fill plug.
          • Roy B.
            • February 1, 1975
            • 7044
            Re: On my '62, I always check to see that it still
            The vent hole can be changed, what I was asking if some one knew that the banjo cast ends that are welded at each end are different in design for Posi and non Posi , that is why you have different bearings, axles and axle retainers.
            Every one is adding a Posi third member claming their Corvette was originally a Posi Vett and judges should look at the banjo ends, like looking at fuel lines for FI vetts. Your the only person responding and I thank you.
            I thought others would be interested BUT!
