Just wanted some advice from the members on a voltage regulator situation.
My ammeter reads normally at start up with a normal discharge as the engine cranks and then the swing to the positive side after start up...The issue is after the car is running for 15 minutes or running down the highway at 2,500 rpm for a while, the ammeter moves to the slight discharge side of the range. On Sunday, it did this but then showed a slight charge as the car was moving at 60MPH...I suspect the voltage reg is sticking or the relays in the regulator are faulty. All other connections are good.
My question is: can the regulator be adjusted and should I try to free up the relays (an just how would I do that?) or just replace the regulator for $30?
Thanks for the advice.......
