Last time I yanked the body...seven years and a top flight latter...I vowed to just drive em. That said, I am knee deep in a firewall and forward resto on my next 1965 project. What tips/techniques recommendations are out there for resto-ing the frame. I have everything apart...control arms etc. Time to degrease, wire wheel, rust convert, prime, and paint. Yes...I MAY have the car judged since it is an original old car. Not so well kept and original to be Bowtie...just tierd and mostly original. Yep...I endlessly read the archives.
Here is the PITA plan (so far...body off would sure make this easier...just cant control the project creep...):
1 Degrease with Simple Green/Super Clean (in my garage so cant use pressure washer).
2 Phosphoric Acid etch and derust the frame (Klean Strip..Phoso Prep $ Etch from HD)
3 Rinse & Wash frame (plus firewall and inner fenders)
4 Sand/grind (using paws, scrotch bright, and angle-grinder)....lots of cracks and crannies...(spring towers...etc)
5 Paint frame-Brush on rustoleum satin black 7777 (primer?)
6 Blackout- SEM Trim Black for firewall, inner fenders, and behind grille
BTW...Still can't find a chunky enough undercoat to match original. Tried most all of the FLAPS stuff including NAPA's asphalt based stuff.
Thanks for feeling my pain and sharing the wisdom.
