Hi guys,
As some of you are aware,I've been looking for some info on the TH400 speedo gears. I have found some conflicting info in the books I have here. In this case I'm going to 336 R&P gears from the original 308's. I was under the impression that I would only have to change the driven gear and want to confirm that. I believe the gear housing changed for the 355- 411 gear sets too but I couldn't find that in any of the manuals here.
The book I have goes to '71 and for a base 350 TH400 with 308 the drive is
#8623311 the driven is # 1359271(37 tooth red) the original gear in the TH400 is white - unknown tooth count?
The 336 uses the same drive gear number and #1362195( 41 tooth Yellow)
Does this sound correct?
Thank you
Thank you
