use of deck plates for factory honing - NCRS Discussion Boards
  • Clem Z.
    • January 1, 2006
    • 9427
    we were posting if deckplates were used at the factory during the honing process. i do not know about other car companies engines but GMs LS series engines have the tapped holes for the head bolts isolated from the cylinder bore walls as they are fixed to the external wall casting with a open space between them and the cylinder walls. this way the torquing of the bolts puts not stress into the cylinder walls to cause distortion like the standard SB and BBC.
  • Chuck S.
    • April 1, 1992
    • 4668
    Re: use of deck plates for factory honing
    Thanks for the info, Clem...I guess out-of-roundness from torqueing is not the problem. A few engines that have the problem probably won't stimulate GM to spend a lot of money to fix it, but solving this mystery sounds like something a gearhead engineer would love to get his teeth into.
    • Clem Z.
      • January 1, 2006
      • 9427
      for a look see about what i posted go to
      When it's time to schedule maintenance or you need vehicle repair services, turn to the vehicle care experts at GM Certified Service. View available services today.
