The judging manuel says both???? It's a 4 speed anyone know? It's a July car if that matters
Which alternator should I have? 69 l71 825? 884?
Double check the JG...
You'll find adjacent to the alternator PN's listed is a column giving application descriptions. The different PN's vary based on the car's configuration (SB vs. BB, HP, A/C and TI v.s standard ignition)...- Top
Re: I looked at it 3 times, maybe I'm dumb but I c
I really think that you will find that the either one could be used. We have not been able to pinpoint any change date. The only thing that I can tell you that is different is that the 884 used an updated rectifier bridge. Cannot even determine a date for that change. Show up with the 882 or 825 correctly dated and you will have no problems.Dick Whittington- Top
JG is likely missing info
Has anybody seen a real 825 alternator dated much into 1969? Why does the service manual (printed in 1968)only list the 825? Why are there NO early original 884's?
The alternators were most likely phased into production. I bet the 825 was first, then there was some upgrade which was called the 882, then it was later replaced by the 884.
Tell me if I'm wrong.
Mark- Top
"Why are there NO early original 884's?"
Well there are, or were -- they are not falling from the trees, however. I have seen one or two in my years as team leader. Some strangely configured internals -- soldered rectifier bridge -- unusual color and configuration of the voltage regulator -- all inside what looks like a standard 884 case.
Once I get over my case of NCRS disease I'll remember the name of the L88 owner in NJ who has an early 884 on his car. Back when I was 1970-72 team leader he, John Pirkle Jr. and I had extensive discussions of the internal differences in the early 884. John even had a collection of some of those parts. Very interesting minutia, but its value for judging -- almost nil -- and that is likely why the info is not in the TIM&JG.Terry- Top
Wonder if it's real.
There is no reason the L88 would have a different alt than a L71 or L89. My Oct 1968 L88 still has its original 825 alternator (prior owner only paid $1000 for the car and had no reason to touch it, car has sat since 1978), and my Feb 1969 L89 has its original 882 (prior owner had it sitting on blocks in the side yard for 6 years and didn't care about restoration before my brother bought it in 1984).
Mark- Top
Re: Wonder if it's real.
I'm not suggesting that the L88 had a different alternator than any other TI or AC equipped 1969 big block. I simply responded to the issue of early built 884 alternators. The early built 884s were different internally than later built 884s. The owner I was trying to think of is Bill Vyn. And yes, I am sure the alternator on his car is the real one that was installed on it in St. Louis.Terry- Top
