C2 Clutch Fork Squeek
  • Donald M.
    • December 1, 1984
    • 498
    My '67 has what I believe to be a squeek from the clutch fork ball pivot inside the bell housing whenever I depress the pedal and also upon releasing the clutch. My question is if I remove the rubber fork boot, will I be able to get some lube on the pivot ball from outside the bellhousing? Thanx!
  • Phil P.
    • April 1, 2006
    • 409
    YES *NM*
    • Chuck R.
      • May 1, 1999
      • 1434
      Re: Maybe too........
      It could also be a dry bushing for the clutch pedal/arm too.
      Just a fleeting thought Don............actually more fleeting by the day
      Chuck
      • Donald M.
        • December 1, 1984
        • 498
        Thanks Chuck and Phil!! *NM*
