My '67 has what I believe to be a squeek from the clutch fork ball pivot inside the bell housing whenever I depress the pedal and also upon releasing the clutch. My question is if I remove the rubber fork boot, will I be able to get some lube on the pivot ball from outside the bellhousing? Thanx!
C2 Clutch Fork Squeek
