ballast resistor question - NCRS Discussion Boards
  • don izzo
    can anyone tell me what the function of the ballast resistor is and if I install a hei distributor in my hot rod 350 ci motor will I still need the resistor?
    Don
  • Steven C.
    • October 23, 2006
    • 186
    Re: ballast resistor question
    The ballast resistor drops the voltage to the coil from 12v, for a points-type ignition. You don't typically need or want it for an HEI ignition, which usually needs a full 12v to the coil.
    Some cars used a ballast resistor inline of a regular wire, others used a special resistance wire which accomplished the same thing. Make sure you have 12v when your coil wire is switchewd on, for a GM HEI system.
    Steve
    • don izzo
      Thanks steve just what I thought *NM*
