67 SB dipstick tube help !! - NCRS Discussion Boards
  • Brandon K.
    • April 1, 1997
    • 474
    OK, I've got the lower dipstick tube in place, and it's sitting flush with the block. Now, how do I get the upper tube in? Is the lower tube supposed to be recessed inside the block? Perhaps someone knows the date of a previous post I can reference? Thanks!
    Brandon
  • Brandon K.
    • April 1, 1997
    • 474
    How do I get lower tube into block?
    I found an archive article that said the lower tube should be recessed about an inch. How do I get it that far in to the block? The (new Long Island Corvette Supply) tube has a lip at the top, and I barely got it so it is even with the block. Was I supposed to grind off part of the lip so it slid in easier? I don't even know if I can get it out now :-(
    • Brandon K.
      • April 1, 1997
      • 474
      Sorry, false alarm
      I managed to drive the lower tube into the block.... once I removed the master cylinder and shielding (duh...) to gain some clearance to work. thanks anyway and have a great evening!
      Brandon
