Hello,
Last summer I used Captain Lee's to strip the paint off my '72. It took it off down to the primer, and then I used lacquer thinner and a Scotch Brite pad to scrub off the primer. I was of the understanding that the lacquer thinner would neutralize any Captain Lee's while at the same time removing the primer.
I have since read of people doing as I did and then using water and/or soap and water at the end. Should I have also water-washed it? The car has been sitting, bare, in the garage for over 1 year since the stripping. Do I need to wash it with water, or would the lacquer thinner have done the trick?
Relatedly, I hear references to using acetone to clean fiberglass. Is there a benefit of lacquer thinner vs. acetone? (I have a couple spots of contaminated 'glass to leach the oils out).
Thank you,
Patricia Brown
Thank you,
Patricia Brown
