67 trim rings - NCRS Discussion Boards
67 trim rings
  • Randy R.
    • March 1, 1983
    • 477
    67 trim rings
    Is there a way to remove the flash chrome from the trim rings? I tried the suggestion to soak them in muratic acid for tem minutes. The fumes were too strong to get a good start with that program. This is with all the garage doors open. The only option I know of is to have a chrome shop remove them.
    A local gentleman has done a nice job of buffing the rest of the stainless on the car, but he says the chrome is preventing him from buffing the rings.
  • Tracy C.
    • July 31, 2003
    • 2739
    Re: 67 trim rings
    Muratic Acid will do the trick but you MUST do it outside to avoid the fumes. If ten minutes isn't enough, go 30. Be sure to have a tub of baking soda/water to dunk them in after the acid bath. This will neutralize the acid. I use a one pound box of soda with 5 gallons of water for this. Rinse with a garden hose following both the acid bath and the soda water bath.
    tc
