Was the 886 starter relay used only in the Corvette? Was it date stamped?
54 starter relay
Tags: None
- Top
Re: 54 starter relay
Not date stamped ,good to carry a replacement if your original burns out, this is a Chevy over drive switch which will work even tho it has a forth post you don't use,(cut it off) the # on the original one cant be seen anyway, you see them on e-bay all the time around $50.00
- Top
