1969 wipers - NCRS Discussion Boards
1969 wipers
  • Rick Hendel
    1969 wipers
    I finally was able to get to get the vacum door to open for the wipers,works great. Now the wipers won"t move . Do I start with a new wiper motor or is it possibly something else. Any ideas? Thanks Rick
  • Ronald D, Rains
    Re: 1969 wipers
    Try the wiper motor relay first, it is the easiest place to check
    RDR
    • Joe T.
      • October 25, 2006
      • 304
      Re: 1969 wipers
      Hi Rick: Maybe you already tried this, but the first place to start is the interlock on the firewall that prevents the wipers from starting while the door is closed. I am not right at the car this minute, but if memory serves me, the wiper door has a plunger attached that pushes an interlock in the engine compartment on the firewall. You can even press the button by hand. If the plunger on the wiper door is not adjusted correctly or is missing, the wiper circiut is dead and you will be chasing a problem that may not exist. Its the easiest place to start, and if it ain't right, nothing will energize. Good luck. I will try to get a picture to you...Regards...Joe 46448
      • Jeff Broughton
        Re: 1969 wipers
        Rick, also don't forget the override switch under the steering column.
