'54 Fuel Pump - NCRS Discussion Boards
'54 Fuel Pump
  • Robert V.
    • November 1, 1987
    • 48
    '54 Fuel Pump
    A previous owner had installed the wrong fuel pump on my '54 Corvette VIN E54S002504. It is a 4666 and has no glass bowl. According to Noland Adams' book and Goat Hill Classics the correct fuel pump is 4132. Noland's book clearly shows a picture of the fuel pump installed with the glass bowl "up". Paul, the owner of Goat Hill Classics insists that the glass bowl goes "down". I tend to believe the picture. Paul doesn't allow anyone to go to his shop to talk to him so it is difficult to deal with him and if he is giving me bogus information, I am hesitant to deal with him. His shop is only 10 miles from my house. Has anyone had any experience with Goat Hill Classics in Long Beach, CA? Is there another supplier that remanufactures the correct fuel pumps? Any info on alternate shops and verification of correct numbers and installation would be greatly appreciated.
    Bob Valeski
    NCRS NO. 12075
  • Chuck G.
    • May 31, 1982
    • 2029
    Re: '54 Fuel Pump
    Glass bowl goes up, just like the 9797. Goat Hill? Well......
    I won't say anything. Chuck
    • Joseph T.
      • April 30, 1976
      • 2074
      Re: '54 Fuel Pump ...#9797
      Here is a 1954 9797 AC fuel pump..installed with glass bowl up..just like my original engine 54...VIN #814
      Joe
      • Joseph T.
        • April 30, 1976
        • 2074
        Upon..further review..and reading Nolands details on the 53/54 pump..the one I pictured if I understand Noland correctly..would be the 1953 and early 1954 pump..since the inlet/outlet is angled 30 degrees on the pump pictured.
        It makes sense that the angle would have been adjusted to parallel with the engine in 54 to accomadate the fuel filter that moved next to the punp for 54.
        Either way the glass bowl was up for 54!
        Hope this helps.
        Joe Trybulec
        • Chuck G.
          • May 31, 1982
          • 2029
          Re: '54 Fuel Pump
          You can make a 4132 configuration out of the more common 9797.
          Just unscrew the top (where the glass bowl is). Rotate the top till the outlet is parallel to the engine block.
          Mark the area on the lower half, drill and tap new holes, and screw it together. VOILA, a 4132 configuration.
          There are some pumps out there that have partially cast recesses to do this very thing. Chuck
          • Roy B.
            • February 1, 1975
            • 7044
            Joe is correct on everything, second design 53-54 Car was the same but part number off.
            • Robert V.
              • November 1, 1987
              • 48
              Re: '54 Fuel Pump
              Thanks Chuck, Joe and Roy for your responses. Chuck, if I read between the lines about Goat hill correctly, my sentiments were the same. Do any of you folks have a suggestion as to where I can get a correct 4132 pump other than Goat Hill? I don't have a 9797. The one I have is a 4666. Thanks.
              Bob
              • Peter K.
                • January 1, 1999
                • 117
                Re: '54 Fuel Pump
                I have an extra NOS 4132 pump for sale, if you are interested, send me a response directly to my email and I will send you a photo.
                • Robert V.
                  • November 1, 1987
                  • 48
                  Re: '54 Fuel Pump
                  Peter,
                  I e-mailed you per your request nearly a week ago and did not receive a reply. I have subsequently found a pump. Thanks for your interest.
                  Bob Valeski
                  • Chris S.
                    • January 1, 2000
                    • 1064
                    Re: '54 Fuel Pump
                    Chuck is right
                    bowl is up
                    on Goat - well.... ummmmm....
                    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
                    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
                    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
                    1957 Corvette - FI 3 sp - Black and Silver
