53-55 trans hump - NCRS Discussion Boards
53-55 trans hump
  • Michael L.
    • July 31, 2005
    • 562
    53-55 trans hump
    The trans hump on my '55 was hacked up to make room for a 4 speed that was installed in place of the Powerglide. When I bought the car, the hump was patched to cover the big square hole that was cut for the shifter. I cannot find a photo or diagram that shows exactly where the correct hole should be cut, what diameter the hole is and how the 4 mounting holes for the screws to attach it to the trans hump are situated. Anybody have a photo or a diagram I can source? I'm getting ready to start body work and patching old repairs is first on my list. I'd like to make sure I have the shifter mount location set up properly.Any shifter install instructions out there?
    TIA,
    Mike
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 53-55 trans hump
    Not for you! He !He! but you could slip over the border and visit me and take measurements , a steel ring was riveted on the under side of the body that mounted the shifter by Four Screws ?
    I dont think there is a install drawing.
    • Michael L.
      • July 31, 2005
      • 562
      I should be able to get all the info I need from under the car. Would it be possible to peek under the carpet to see the finish on the glass on the trans hump? I'm going to Vegas on a small consulting job this weekend, but maybe after Thanksgiving, first week of December I could make the trip on a weekend. I'll call you to firm up details. Is the wind as bad today in Nevada City as it is in Reno / Sparks? YIKES!
      • Roy B.
        • February 1, 1975
        • 7044
        I cant remove the carpet but the glass looks the same as the rest of the hump, wind is OK here,sounds good come up.
        • Dave Suesz
          Mike- Did you
          find my trans lever dimension useful?
