Hi all,
I just want to make sure that my axles are in correctly. I put the metal cover on the axle and had new bearings pressed onto the axles. Then I slid the brake backing plate on, inserted the axle into the housing, and tightened down the four bolts that hold the cover and back plate onto the end of the axle housing.
I am concerned about whether there is something else that holds the axles in other than just this cover. Is there something that holds the axles in securely? Should I somehow have the axles pressed into the housing? Or ?
Bob
Bob
