66 single to dual master cyld - NCRS Discussion Boards
  • Richard E.
    • 247
    I am considering converting my stock single master cylinder to a aftermarket dual master cylinder. Has anyone had experience with this conversion, good or bad?. Anything to be cautious of? Any special brake or master cylinder bleeding techniques required etc.? Would it be good to consider adding power boost at the same time? Appreciate all comments. Thank you in advance.
    Re: 66 single to dual master cyld
    Make sure you get a master cylinder listed only for Corvette 4-wheel disc brake usage; those for disc/drum usage won't work, as they have an RPV in the rear outlet that will drag the rear brakes.
