1967 jack - NCRS Discussion Boards
1967 jack
  • Joseph E.
    • March 1, 2006
    • 175
    1967 jack
    Should the "U" portion of the jack with the nut on it (opposite the drive end) face inward or outward for a car in the low 20,000 serial number range? If any of the members have or know of the correct style jack dated 7 C, D or E for sale, I would greatly appreciate hearing from them. Thank you.
    Joe
    #45420
  • Gerard F.
    • June 30, 2004
    • 3803
    Re: 1967 jack
    Joseph,
    Not sure if there is a correct orientation of the jack in the jack compartment.
    But here is a 7D which just sold on ebay for $860:
    (You may need to copy and paste the above link to the top address bar to view it)
    Just gave my original 7E a pat on the nut and whispered to it "Too much money"
    Jerry Fuccillo
    #42179
    Jerry Fuccillo
    • Joe R.
      • March 1, 2002
      • 1356
      Re: 1967 jack
      I believe that the reproduction 67 jack sold by Paragon and several other vendors is a very good reproduction. I bought one and have used it for Flight judging several times with no deductions. It compares well with the photos I have of original 67 jacks.
      The reproduction contains an extra tubular steel sleeve on the screw shaft that I think the original 67 jacks did not have, but this part is easy to remove.
      I can't comment on the reproduction jack handle because I still have my original handle.
      Regarding the date coding, I think that some vendors will stamp the reproduction jack for an additional fee, or you can do it yourself. Technically, you may not need a date code for Flight judging. I believe that date codes first appeared on jacks around January 67, but under the "six month rule" for date coding you could theoretically have an undated jack for a car built as late as July.
      • Stephen L.
        • May 31, 1984
        • 3148
        Re: 1967 jack
        FWIW...
        Photos of my restored jack... April Build date
