66 & 67 coils - NCRS Discussion Boards
66 & 67 coils
  • Richard S.
    • November 1, 1994
    • 809
    66 & 67 coils
    I recently bought two reproduction coils...one for my 66 standard ignition 427/390 car(232)and one formy 67 T.I.ignition 427/435 car(263). These are GM Reatoration Parts Delco Remy coils.(Boxes say:Made in China)
    How can I tell if these coils are "stock rated coils"? Thanks for the help.
  • Clem Z.
    • January 1, 2006
    • 9427
    the shop manuals gives the different resistance
    readings for the different coils.
    • Richard S.
      • November 1, 1994
      • 809
      Re: the shop manuals gives the different resistanc
      Thanks Clem....but....I guess I was not clear in my message. How do I measure the voltage and what numbers am I looking for......thanks and very best regards,
      Rick.
      • Clem Z.
        • January 1, 2006
        • 9427
        if you check the resistance and it matches the
        manual specs they should work. the difference in the 2 coil is the turns ratio and the resistance test will show that. you can find a shop with a coil tester and have them check the output of the coils. the points coil is easy to check on the bench with a old distributor and a battery. the TI will need a amp,black box, to bench test it.i would think you could also use a HEI distributor to bench test the TI coil
        • Clem Z.
          • January 1, 2006
          • 9427
          use a oil pump drive shaft in chucked in a
          electric drill to spin the distributor that is clamped in the bench vise. this is the way i used to set the dwell on points distributor on the bench.
