Rochester Carb - NCRS Discussion Boards
Rochester Carb
  • Mike Walsh
    Rochester Carb
    Anyone know of a great Carb shop to work over a 78 Rochester 4 barrel Carburetor.
    I purchased a '78 L-82 that had only 3 miles on the Vette and the car has sat for 22 years. Ran a cleaner thru it but the idle still isn't they way it should be.
    I am showing the Vette at NCRS so I want to keep it original but get it reworked.
    I live in NJ.
    Thanks for your help
    Mike W
    Re: Rochester Carb
    Mike-----
    Jerry Luck Motorsports seems to be the guy that most folks on this board have had good experiences with relative to Rochester/Holley rebuilds. I don't have his number handy, but I'm sure that you can find it in the archives; it's been mentioned many times here.
    Notwithstanding this, your carburetor probably only requires installation of a minor rebuild kit and a float. If you have any mechanical ability, you can install these without too much trouble. No special tools, at all, are required. Rochester Q-Jets seem more intimidating to overhaul than they actually are. Use the Chevrolet Service Manual or Doug Roe's Rochester Carburetor Manual as a reference.
    • Bill D.
      • January 1, 1985
      • 76
      Re: Rochester Carb
      If your carb needs cosmetic restoration, Jerry Luck is the man! His phone 314-895-1551. If mechanical function is the only issue, do as Joe suggests. WB
