Media Blasting Aluminum Help - NCRS Discussion Boards
  • Jeff C.
    • August 15, 2012
    • 35
    Hello, I'm going to purchase a sand/bead blasting cabinet soon. Here's my question: for aluminum parts, i.e. intake and valve covers (1965 L79) do I need to be concerned about damaging the aluminum? Do I need to use a specific media for aluminum parts? If so, can anyone recommend one? Thanks!
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: Media Blasting Aluminum Help
    Walnut shucks and low pressure will clean up aluminum.
    Lyle
    • Wayne P.
      • August 31, 1975
      • 1025
      Glass beads work and I've never damaged anything. The finish will NOT appear as original.
      • Greg L.
        • March 1, 2006
        • 2291
        What are Walnut shucks and will they leave aluminum the nice bright color that it had when it was new? .....still trying to figure out that "re-skinning" secret!!!
        • Chuck S.
          • April 1, 1992
          • 4668
          Walnut shells. You should know about walnut shells, Greg. They used to run walnut shell media through idling aircraft turbines to clean the compressor blading without damage.
          Re-skinning aluminum is a tumbling process rather than a blasting process.
          • Harmon C.
            • August 31, 1994
            • 3228
            Walnut media will remove stains. The color will be fine for me but others may say it is not original. As far as NCRS judge deductions its a crap shoot on every item judged if the finish has been messed with. If you think you have a finish perfect you just have not yet met the judge who thinks it's wrong.
            Lyle
            Lyle
            • Greg L.
              • March 1, 2006
              • 2291
              Yes Chuck I do remember hearing that was a procedure on some turbines however the type that I initialy worked on (TPE-331) series didn't call for any type of wash so I never had the chance to use them. I wouldn't have used them on my intake anyways because that was before the internet and before I knew about the NCRS so SANDBLASTING was how I "restored" my intake back then!
              Sure glad I found out about you all the second time around!
                Greg -
                Got lotsa hours in an MU-2K with TPE-331's - nice engines, but the auto start sequencer modules cost about the same as a car!
