Re: Ok I need some support here
Been picking them up like this for many years, and have never given it a second thought.
Your post however, got me to thinking, and I looked up the tensile strenght of several grades of bolts. Grade 2 in this size will have a 55,000 PSI proof strength, Grade 5 will have 85,000, and Grade 8 will have 120,000.
I then calculated the crossectional area of a 1/4" bolt at .049 Square inches.
The proof strength of a single bolt would be 2700 pounds for a Grade 2, 4165 for a Grade 5, and 5850 pounds for a Grade 8.
If you multiply this times 4 for the 4 bolts, you will find that even with crappy Grade 2 bolts, you will have a proof strength of over 10,000 pounds of load. Even if you assume that the threads in the manifold are not in perfect condition, you will still have a load ability of over 5,000 lbs, or roughly 10 times the weight of a smallblock engine! With Grade 8 bolts, the load capability of these 4 bolts will exceed 20,000 lbs.
Pick it up by that carb plate, and don't give it a thought, like I did for years! LOL
Regards, John McGraw
