C2 Master Cylinder Resleeve
  • Michael M.
    • November 1, 2001
    • 404
    #1
    an someone suggest a reliable person or business to install stainless sleeve in original 65 PB Master Cylinder? Thanks!
  • Jim V.
    • November 1, 1991
    • 587
    Re: C2 Master Cylinder Resleeve
    I hear White Post Restoration (whitepost.com) is recommended by many. I have not personally used them...yet.
    • Brian M.
      • February 1, 1997
      • 1812
      White Post will probably suggest a Brass sleeve. Great service.
      • Joel T.
        • May 1, 2005
        • 765
        I just sent my 1965 PB unit off to Apple Hydraulics... Got a few recommendations for them from this board as well as some friends who are into restoration work.
        • Chuck W.
          • June 1, 2002
          • 257
          If you are going to use DOT 5 fluid, White Post will NOT warranty their work. I have switched to Brake & Equipment Warehouse, 455 Harrison St, Minneapolis, MN 55413. Speak to Rob at 800-233-4053. They have done about 6 masters for me and probably 20 wheel cylinders without a hitch. I found their work less expensive and the quality better than White Post. I had several masters sleeved and rebuilt by White Post with parts left out of the rebuild. Old Billy wouldn't stand behind their work so I won't use them again. I also understand that White Post outsources their work to someone in Florida.
          White Post uses brass whereas B&E uses stainless.
          • Michael M.
            • November 1, 2001
            • 404
            Thanks for the info. Thats just what I needed before I made a mistake.
            • Michael M.
              • November 1, 2001
              • 404
              Called Ron. Nice guy and very reasonable! I got to go box up. Thanks for the info! Mike
