I have a very basic issue to get some info on being relatively new to NCRS....My odometer has stopped working but the speedometer is now better than ever! In the past, the needle on the speedomter would gyrate wildly...swinging from 20 to 60MPH...Now, it works perfectly, but before this happened, I heard what sounded like some girgling/gear grinding coming from the dash, and the odometer then stopped. This was at highway speed of about 55MPH.
I have a new speedometer cable but before I install it, my question is will a new speedo cable "cure" the odometer failure or is that an internal issue with the speedometer itself?
Can the odometer be fixed separately or be adjusted separately from the speedo? Who are the best sources to do this kind of repair or is there something that I can do to get it to work again? I am looking in the assembly manual and cannot get the level of detail needed....
Appreciate the advice....
