55 owner guys
  • Roy B.
    • February 1, 1975
    • 7044
    #1
    55 owner guys
    Asking owners which are few here about the fire wall linkage gas flat throttle arm you see that has a bend in it, most all I've ever seen original has the same but I also see straight arms, trying to understand if it's a early or late change . The straight ones I've seen hit the plug wires at full throttle.
    The rubber line you see is for my power brake booster if your interested which works great if you C1 guys wont PB!
  • Verle R.
    • March 1, 1989
    • 1163
    Re: 55 owner guys
    Roy,
    Don't tell them about your power brakes, it will ruin your reputation.
    Verle
    • Roy B.
      • February 1, 1975
      • 7044
      Re: 55 owner guys
      Reputation ? I have 2 right now, 1. I'm bad bad bad 2. I'm vary bad bad bad
      I'm on the fringes of NCRS tho I know NCRS is great but I'm not a funatic
      • Michael L.
        • August 1, 2005
        • 562
        Re: 55 owner guys
        Roy, just checked mine, it is straight, my car is #175.
        Mike
        Sparks, NV
        • Bernard M.
          • September 1, 1994
          • 338
          Re: 55 owner guys
          Roy, Looks the same as 56-57 to me. If so, that might ID it as a late change. 56-57 are the same as one another and differ from 58 & up where they clamp to the pivot. Does it have a large S stamped in the opposite side?
          • Mike M.
            • June 1, 1974
            • 8288
            Re: 55 owner guys
            roy: been trying to buy a 55 t-bird PB booster, on line , for past 4 months without success.its for the 41 willys. where did you get yours? mike
            • Roy B.
              • February 1, 1975
              • 7044
              Re: 55 owner guys "Bernard" YES *NM*
              • Russ U.
                • April 1, 2004
                • 345
                Re: 55 owner guys
                Roy-
                Based on some pictures I have, VIN #447 has a bent throttle arm, with a large S stamped in it as well.
                Russ
                • Michael L.
                  • August 1, 2005
                  • 562
                  Re: 55 owner guys
                  Roy, my straight arm on #175 has a large C stamp.
                  Mike
