Warning: Undefined array key 5516 in .../vb/library/content.php on line 3508
Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510
Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737
Warning: Undefined array key "online" in .../vb/library/content.php on line 3522
Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614
Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165
Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182
Warning: Undefined array key "posts" in .../vb/api/user.php on line 183
Warning: Undefined array key "posts" in .../vb/api/user.php on line 189
Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480
Warning: Undefined array key "userid" in .../vb/api/user.php on line 204
Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246
Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342
Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594
Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610
Roof Panel to door weatherstrip on a 66 Coupe. -
NCRS Discussion Boards
If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
My 66 Coupe has just been painted and new weather stripping has been installed on both doors. The roof panel to door seal is also new. The doors have been adjusted and close nicely. However when I put the new roof panel seal on and close it against the new weatherstrip on the door it forces the front corner of the door over the vent window out a bit and causes a leak when we water tested it. Remove the roof panel seal and close the door and no leak. So it appears the roof panel seal is too thick. We could trim the seal I suppose. Does anybody have any tips or suggestions. Thanks in advance. Dennis
Re: Roof Panel to door weatherstrip on a 66 Coupe.
I had/have similar problems on my '66 Coupe. The best thing for it was time and sun. Part the car outside in the sun and it softens up and over time the fit is becoming much better. Good luck.
