I think I've got this figured out but need your confirmation. Here's a couple of K66 stationary pole pieces that I picked up at a Vermont swap meet in the early '90s. When I checked my GM catalogs they were listing Gr 2.372 # 1964276 as for fuel injected distributors with transistor ignition only. They show as no longer available in my 1980 GM price book.
In VETTE magazine Nov 1991 issue, they say the difference with the OTHER stationary pole # 1960779 (all non-F.I. applications) is that the sleeve pressed into the breaker plate (points ignition) or the K66 pole plate is shorter for F.I. (0.325") than for non-L84 distrib's (0.405"). So that means if I want to use one for a carbureted distrib, I'd have to transfer the sleeve, right ?
And what about that brass washer ? Same VETTE article says NO brass under the stationary pole piece for F.I. distrib's. And why is this washer Gr 2.385 @ 1961927, indicated for ALL K66 distrib's (no exclusion specified for F.I.) ? And (Joe L ?) why does this part only show up in the Corvette-only parts catalogs (P&A30B's) and not in the general Chevrolet P & A 30 series ?
