C1: Horn bolts - NCRS Discussion Boards
C1: Horn bolts
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12695
    C1: Horn bolts
    I'm in the process of rebuilding the old '59 Crown Sapphire and I didn't bag the horn bolds with the horns (dumb I know). What dimensions and head marking do these bold have?
    greetings,
    Rob.
    Rob.
    NCRS Software Developer
  • Gary Bishop
    Re: C1: Horn bolts
    I was waitin for an answer also. I think mine were square head with a square nut fastened to the inner body.
    • Gary Bishop
      Re: C1: Horn bolts
      • Rob M.
        NCRS IT Developer
        • January 1, 2004
        • 12695
        HHHHHHHHHEEEEEEEEEEEEELLLLLLLLLLPPPPPPPPPPP!!!!!!!
        Appearantly this is difficult question???
        I know on the inside there is a little plate rivetted to the body with a square nut attached. I just don't know the bolt size and head-marking...
        your answers are appreciated!
        Rob.
        • Rob M.
          NCRS IT Developer
          • January 1, 2004
          • 12695
          Rob.
          • Russ U.
            • April 1, 2004
            • 345
            Re: HHHHHHHHHEEEEEEEEEEEEELLLLLLLLLLPPPPPPPPPPP!!!
            Rob-
            I am not sure I know exactly what you are looking for. I will post some pics from my 59. I think my horns are original. Let me know if you need some different pic angles.
            Can you get the bolt size from the AIM?
            Russ
            • Russ U.
              • April 1, 2004
              • 345
              Rob-
              Russ
              • Russ U.
                • April 1, 2004
                • 345
                Different angle of bracket
                • Russ U.
                  • April 1, 2004
                  • 345
                  • Rob M.
                    NCRS IT Developer
                    • January 1, 2004
                    • 12695
                    Hi Russ,
                    Okm, these pictures do help a lot. If I'm seeing it correctly there are no markings at all on the bolt...
                    thanks again,
                    Rob.
                    Rob.
                    • Rob M.
                      NCRS IT Developer
                      • January 1, 2004
                      • 12695
                      Hi Russ,
                      thanks again,
                      Rob.
                      Rob.
                      • Richard B.
                        • July 31, 1981
                        • 77
                        Rob,
                        I have done a LOT of research on the correct head markings on bolts for the solid axle cars. What you are looking for is the following:
                        Bolt head size: 1/2 inch
                        Diameter: 5/16 18
                        Length: 30/32
                        Head Marking: T (on the edge; with the base of the T edge of the bolt)
                        I hope this helps. If you have any further questions, feel free to contact me for either bolt head markings of with paint/color finishes.
                        Richard Brodeur
                        NCRS #4779
                        • Rob M.
                          NCRS IT Developer
                          • January 1, 2004
                          • 12695
                          Hi Richard,
                          Thanks for this info!!!
                          I've found two bolts which I believed were the onces which were used on the horns. I'll check tomorrow if they indeed have the mentioned T head marking (and sizes).
                          I might contact you now and then on one of the other bolts during the re-assemble phase (I'm afraid I relied a bit to much on my memory during the bagging and tagging process)!
                          greetings,
                          Rob.
                          Rob.
